dont jump your pinz.
norcal pinz
Post by norcal pinz »
I'm pretty sure that the manual says not to jump your pinzgauer? but, the newer model pinzgauer, in the updated video catch a little air! my question is there anything you can do to modify the suspension so you can jump a little?
710M 1972
710k 1974
Profpinz
Post by Profpinz »
If the check straps were damaged or missing it could do damage in the diff (the axle casings could "intersect" with each other at the bottom of the diff housing) but otherwise I can't see any problem.....well no more than any other vehicle :wink:
1997, 718 6X6 Pinzgauer
Personally, we've had good luck jumping Ford vans around here. The front end is really tough (unless you auger it in...) and the weight distribution is pretty good.
Anyway, install some suspension travel limit chains on all four corners and truss the rear axle, and they'll last for years. 8)
