spring removal
Posted: Mon Apr 20, 2009 9:09 pm
by norcal pinz
do i need the special tool or can i use a regular spring compressor?
Posted: Mon Apr 20, 2009 10:51 pm
I've used a normal spring compressor successfully. But it did take a bit of arranging for it to clear, as it was a sort of tight fit. That was fronts only, as I've got a 712.
Posted: Tue Apr 21, 2009 9:41 am
by EvanH
I have had moderate success with a spring compressor. I "removed" the spring as a side effect of pulling the axle, so I dindn't need a compressor for that. When I used a cheap compressor to reinstall the spring, it broke under a lot of tension, sending both ends rocketing across the shed.
I had my best luck when I used my hydraulic press to compress the spring, then the compressor to hold it compressed while I installed it. The setup made me very nervous. Plus the upper part of the spring compressor fouled the body and made it hard to get the spring into position.
-Evan
Posted: Tue Apr 21, 2009 10:36 pm
by norcal pinz
i wonder how well the factory tool works? how beefy it is, and does it make the job easier, than the cheapy ones.
oh yeah.
Posted: Tue Apr 21, 2009 10:39 pm
by norcal pinz
is there an alternative to using the factory springs?cheaper ones?
Posted: Tue Apr 21, 2009 11:33 pm
Don't you guys know how to use the search function?
There is a cad drawing(ctsy Bernard) , as well as pictures and instructions on how to make this tool already posted.
The factory tool (or the home made one) is virtually the only safe way to remove front springs short of loosening the body mounts and lifting it till the springs unload. Much easier to use the proper tool.
Posted: Wed Apr 22, 2009 12:05 am
by M Wehrman
Come on Jim,a little patience goes a long way....We can't all be stars! :lol:
Posted: Wed Apr 22, 2009 12:12 am
by M Wehrman
Posted: Wed Apr 22, 2009 12:16 am
by M Wehrman
Well,it would seem that I double posted, :roll: ...Never claimed to know how to use a 'puter! :lol:
Posted: Wed Apr 22, 2009 12:32 am
:shock: I just ment it would save time to search for re occouring special service tool info. I
Jim LaGuardia wrote:Here is a couple pics of the first one I made, It is a modified version of the factory compressor(the original had a 2 piece base).
I will warn you not to use cheap quality anything when making a tool that can do major damage if not made correctly :!:
Posted: Wed Apr 22, 2009 12:38 am
by M Wehrman
I agree..springs under pressure are quite the bomb when compressed!
Thanks for the refresher pics!
Mark
Posted: Wed Apr 22, 2009 2:40 am
I once visited a shop that had a patched hole in the ceiling from a coil spring that got loose .......................
Posted: Wed Apr 22, 2009 5:24 am
by hrafn
Jim LaGuardia wrote:There is a cad drawing(ctsy Bernard) , as well as pictures and instructions on how to make this tool already posted.
Jim,
You mention a CAD drawing, but I have been unable to find it.
BTW, my EFI install is almost complete. Just need to finalize throttle linkage and install a more reliable 24-12 volt converter. Started on the first attempt.
Posted: Wed Apr 22, 2009 9:40 am
by Erik712m
Wish I would have taken measurements and pic's of the factory one before I sent it back.
Posted: Wed Apr 22, 2009 4:41 pm
Erik, the only spec you need to make the tool is 10 1/2". That is what the spring must be compressed to to be removed/installed.
All this is in the repair manual......................................... :P
