Clutch Resevoir behind steering wheel
matthewc66
Post by matthewc66 »
I have a slight leak in the reservoir behind the steering wheel which I believe is the fluid for the clutch.
It leaks down the clutch pedal if I am driving all day but in normal around town driving it does not leak. I want to monitor fluid usage and it is getting down to the "minimum" level in the reservoir.
What type of fluid do you use in the reservoir?
I used the search function but didn't see anything.
Thanks, Matt
Dot 3 brake fluid.
Matt, it is easy to remove and rebuild. Just remove the hard line and the 2 mounting bolts and it comes right off.
