what's this for??
what's this for??
Two bolts in the upper part of the front window side rail, pair on each side about 6 inches apart.
Before I mess with them I would like to know the purpose for them.
Morris
Erik712m
Post by Erik712m »
Used to mount chrome sun shade. Image
Mounting bolts for the blue flashing lights. Image
what's this for??
thanks,
I had been looking on EI and SAV sites for chrome sunshade and no luck.
The lights make sense.
The Austrian "M"s have a differnt release system for the front tops, and a clamp is mounted to each side. It is also used for the front support for a "over the cab" rack, and/or tire mount when a speciality body is fitted to a "T" .
If you don't like that answer, I can invent one more imaginative than Erik's. :roll:
Those mounting holes have been used for several different things, as aftermarket accessories company see a use
what's this for??
Thanks Dave,
I have seen you in action and I have no doubt you can come up with something imaginative.
I just did not want to loosen them and find something slipped down inside.
There were bolts on the Mog windscreen that were best not messed with. Did not want a remake of that disaster with the pinz.
