The second cat arrived last week
Double your pleasure,
Double your fun,
If it weren't for the name tag,
You couldn't tell which one.
( besides his kit on his back)
Over the weekend, after stowing the tracks , and removing the CF's ROPS, I got down into the bowels of the new cat.
Here you can see the VW/Audi 3 speed auto tranny, and the disc brakes from a LR Defender 110 ( there is also another set of disc brakes out board, behind the center tires)
Access is through 4 panels with 2 cam locks each, and 1 with 2 quick release screws
This is of the VW 1.9TDI .... not much different than the Turbo diesel that was powering VW Jettas and Passats..
you can see the fan which had selfdestructed at some point.... probably due to someone launching it into lake at too steep an angle, and water entering the front air intake
On the sidewall to the left of the disc brake, you see the oil reservoir for the automatic lube system for the chains and bearings.
And from the other side, you see one of the self loading ramps in it's storage area. Also the mid mount for the "self loading" 8000lb winch, which can be remounted to the tabs located at the rear, or to a set on the front, if a need arises.
