Engine Oil Viscosity
jrcotner
Post by jrcotner »
The user manual for my Pinz recommends 30W oil, with no specified season or temperature range. Various sources recommended 20W50 for summer, and 10W30 for winter. My new English service manual recommends 15W50 oil, again no specified temp range.
Is there a chart or other document which recommends the engine oil viscosity for the Pinz by temp range or season?
John Cotner
New Ulm, MN
viscosity
I suppose that there are lots of differing ideas on this but, I use SAE 30 all the time.There seemed to be no reason to alter from the recommendations of the design. I also use SAE 90 in the gear boxes, per the book.
I have made alterations in the appearance of my pinz, but it is not a show truck.
jrcotner
Post by jrcotner »
Thanks for the info.
John Cotner
New Ulm, MN
pinzwheeling
Re: viscosity
Post by pinzwheeling »
krick3tt wrote:I suppose that there are lots of differing ideas on this but, I use SAE 30 all the time.There seemed to be no reason to alter from the recommendations of the design. I also use SAE 90 in the gear boxes, per the book.
Probably a smart idea. I've been using 10w-40 Castrol GTX in all my trucks without issue, but I believe that I'm probably getting some static leaks when cold because of it. I'm going to change to straight 30 weight in the future
Michael
email: rosenblumm@gmail.com
This was also discussed previously: http://real4x4forums.com/PinzgauerBBS/v ... +viscosity
I'm still sticking with Castrol, but I've switched to the 20w50.
Jim recommends is, so it's most likely right... 8)
HOOPS PINZ
Post by HOOPS PINZ »
I have found that Castrol GTX 15-40 high mileage works best for me smokes less on start up and helps the oil seals. I have tried a few other oils but the high mileage does help the older Pinz engines.
30 SAE is the recommended but the Castrol works from 15 through to 40 so its better for start up etc
Steve
