Flywheel bolts torque setting?
WdeLange
Post by WdeLange »
Hi guys, I am busy with a clucth job on my Pinz. 250ft/lbs seems a bit high for the flywheel bolts??? (I took the flywheel off to replace the deep grove end bearing.)
250ft lbs is the spec, deal with it :shock:
lindenengineering
Post by lindenengineering »
Yes deal with it is the maxim.
Put in another way torque to 22lbs ft mark the bolt head with a paint stick/white out, then turn ONE FLAT. You will end up at the same torque after putting the bolts into stretch.
I usually put two of the clutch pressure plate bolts into any two consecutive holes, jam a 3/8th long socket extension between them and the gearbox mounting stud, then bring a 1/2 Snappy knuckle bar & 21mm (7/8ths) socket to bear.
You will feel them go into stretch--feels like a rubber bolt!
Charles Atlas course perhaps
Dennis :lol:
OOOps no customer bashing now
WdeLange
Post by WdeLange »
Short and sweet, thanks guys.
250ft lbs would be 338Nm...
