Sloppy steering
Sloppy steering
I've noticed a substantial amount of center freeplay in my steering. Do i simply tighten the adjustment on the front of the steering box? Where do i look for the most common cases of worn parts?
pinzdriver
sloppy steering
I would try adjusting the steering first jack up the ft end with wheels off the ground
adj the gear box so you get a little drag in the center swing from lt to rt
just fell a little drag
it will be loose on both ends. If you still have play you need to rebuild the gear box.
tony in az 73 pinz 6X6
pinzdoctor is the name,pinz repair is the game!
Twin Pinzies
