Hand throttle linkage
My hand throttle is just a square section rod about 4" long which just comes right out if I pull it - how is it supposed to be connected to the throttle pedal (not clear in the parts diagram)?
Robin
Pinzgauer 710K
MegaJolt ignition
(upgrading to MicroSquirt)
Robin
Pinzgauer 710K
MegaJolt ignition
throttle
There is a screw into a cylinder that captures the 'wire' of the throttle, the cable. Mine was as yours and it took me awhile to figure it out.
You can order a new assembly and it makes the whole thing work.
throttle
Winter Beater
hand throttle
I removed the T with the square end and drilled a hole. Insert a section of wire and used Silver solder to make an extension. It works but I think a flexible wire (like a sink plug) would work better. Sometimes the stiff wire gets bent and makes it difficult to set the idle accurately.
My hand throttle ( the one attached next to the choke control on floor in front of drivers seat) is attached to a round rod that attaches to the caburator throttle linkage which activates the dual carbs. Screw adjustments on pivoting round connectors. Only the choke is cable actuated. Seems there are two ways the throttle can be activated.
Capt Xmas
Winter Beater
linkage
Captxmas, I think we are talking about the same thing. My cable was missing -I only had the "T" and needed to make something that would work. I still find it difficult to set the idle properly and will change it to something that pivots better.
Sorry to open an old thread again.
Have just threaded the square section bar M5. Now I can thread one of my throttle linkages onto it and work out something from there on as keeping her idling this evening in the cold was difficult!
Robin
Pinzgauer 710K
MegaJolt ignition
Robin
Pinzgauer 710K
MegaJolt ignition
cronapress
To piggyback on Robin's thread... my hand throttle works OK when you pull it up..... but it won't stay up ! Turning the knob clockwise should "seize" the assy. but it doesn't. Is there an easy fix lurking ? Got quite a bit of very cool white stuff here at the moment, so won't be mauling about underneath for a while ! All help appreciated - as always.
Thanks.
Mike 712M
Thanks.
Mike 712M
cronapress
- ScottishPinz
cronapress
Mine doesn't require the use of the hand throttle for idling at all. It comes in handy after the river crossing at a certain bothy every month. (You know the one ScottishPinz).
After reaching the tarmac, I dry out the brakes with the hand throttle on for a few hundred yards until they "bite" uniformly . Have to keep the hand throttle held in place whilst steering ! Not recommended really I suppose.
