Hand throttle linkage
Posted: Sat May 29, 2010 3:01 pm
by spandit
My hand throttle is just a square section rod about 4" long which just comes right out if I pull it - how is it supposed to be connected to the throttle pedal (not clear in the parts diagram)?
throttle
Posted: Sat May 29, 2010 10:24 pm
by krick3tt
There is a screw into a cylinder that captures the 'wire' of the throttle, the cable. Mine was as yours and it took me awhile to figure it out.
You can order a new assembly and it makes the whole thing work.
throttle
Posted: Sat May 29, 2010 10:27 pm
by krick3tt
hand throttle
Posted: Thu Aug 12, 2010 1:58 pm
by Winter Beater
I removed the T with the square end and drilled a hole. Insert a section of wire and used Silver solder to make an extension. It works but I think a flexible wire (like a sink plug) would work better. Sometimes the stiff wire gets bent and makes it difficult to set the idle accurately.
Posted: Fri Aug 13, 2010 12:53 pm
by captxmas
My hand throttle ( the one attached next to the choke control on floor in front of drivers seat) is attached to a round rod that attaches to the caburator throttle linkage which activates the dual carbs. Screw adjustments on pivoting round connectors. Only the choke is cable actuated. Seems there are two ways the throttle can be activated.
linkage
Posted: Fri Aug 27, 2010 9:28 am
by Winter Beater
Captxmas, I think we are talking about the same thing. My cable was missing -I only had the "T" and needed to make something that would work. I still find it difficult to set the idle properly and will change it to something that pivots better.
Posted: Mon Nov 29, 2010 1:34 pm
by spandit
Sorry to open an old thread again.
Have just threaded the square section bar M5. Now I can thread one of my throttle linkages onto it and work out something from there on as keeping her idling this evening in the cold was difficult!
Posted: Tue Nov 30, 2010 4:37 am
by cronapress
To piggyback on Robin's thread... my hand throttle works OK when you pull it up..... but it won't stay up ! Turning the knob clockwise should "seize" the assy. but it doesn't. Is there an easy fix lurking ? Got quite a bit of very cool white stuff here at the moment, so won't be mauling about underneath for a while ! All help appreciated - as always.
Thanks.
Mike 712M
Posted: Tue Nov 30, 2010 6:00 am
by spandit
Mike,
There is a small nut around the square rod - try turning it upside down if you can - this fixed mine
Posted: Tue Nov 30, 2010 6:09 am
by cronapress
Thanks for that Robin. I'll give that a try.
Mike.
712M
Posted: Tue Nov 30, 2010 11:02 am
by ScottishPinz
The hand throttle shouldn't be needed to keep the truck idling should it?
Posted: Tue Nov 30, 2010 11:10 am
by spandit
In a properly tuned vehicle when it's not freezing, yes, but mine needs a few revs initially
Posted: Tue Nov 30, 2010 11:21 am
by cronapress
Mine doesn't require the use of the hand throttle for idling at all. It comes in handy after the river crossing at a certain bothy every month. (You know the one ScottishPinz).
After reaching the tarmac, I dry out the brakes with the hand throttle on for a few hundred yards until they "bite" uniformly . Have to keep the hand throttle held in place whilst steering ! Not recommended really I suppose.
