Wheels and tires ???
FNG here, so bare with me. Are there any other wheels from other vehicals that fit the pinz? How big of a tire can you you stuff under it? I have 34" LTB on there now but am curious as to what will fit. Thanks alot guys.
Hell, lets just wing it and see were we end up!
wrangler0511
The only vehicle that has the same bolt pattern as the Pinzgauer
that I know of is the Ford Transit FT300.
The only benefit of those wheels is that they are designed for
tubeless use.
Other then that there are some custom wheels on the market that
fit the Pinz.
I think the limit is a narrow 35" tire.
Right now I run tires that would translate into a 35x11,5-16 tire.
They do rub occasionally but nothing to worry about.
Richard
tubeless use.
fit the Pinz.
Richard
thanks
thanks alot. I seen the aftermarket ones but cant find a price...there are 4 of them forsale on EBAY for $365 EA, but I dont know the going rate for them or even if they still make them or not. What do you tires rub on? Do you notice a huge diff in the rotational wt?
