Does this clutch look worth using
Posted: Thu Oct 07, 2010 8:01 pm
by mopar
I blew my clutch getting stuck in a mud hole. A friend of mine gave me a used clutch he believes to have almost no miles on . Not having any experience with doing a clutch I was wondering if you could tell by looking if this clutch would be worth using because the price is right or does it look very worn and I would not get any significant amount of use from it before I need to change it again?
Posted: Thu Oct 07, 2010 8:12 pm
Best to get new unless you want to do it again :shock:
Get the reman parts if you need to save a few $
Posted: Thu Oct 07, 2010 9:23 pm
by Pinzgauer Pete
If you decide not to use this clutch please send it to me...I will pay the shipping costs....regards!
Posted: Fri Oct 08, 2010 12:31 am
You do realize the disk is burnt and the pressure plate surface shows evidence of heat damage from slippage and may chatter if used:(
Weak pressure plates will only get worse.
You can get all new BMW 733i clutch and pressure plate for around $250
Look at the reman units at SAV. Good prices and I have installed a few of them with no issues :wink:
Re: Does this clutch look worth using
Posted: Fri Apr 08, 2011 2:08 pm
by stiffler4444
Jim, does the BMW 733i clutch have the same longevity of the OEM equip? I don't want to cheap out, but a good value is always on my radar......
Seems the pressure plate is the issue on my truck, but a new one here is $200. If I can get the disc and plate for a bit more, sounds reasonable.
tx Dave
Posted: Fri Apr 08, 2011 2:52 pm
The BMW clutch is more robust(rated over 230HP) vs 89hp. Much better than stock. Remans from SAV are also a good choice.
Posted: Fri Apr 08, 2011 3:09 pm
by stiffler4444
Thanks Jim, I'll check the $$$ on the Beemer clutches here in Ontario.
