Slave Cylinder Ring
Slave Cylinder Ring
Admittedly a very basic question: Any one have a tip on getting the retaining ring out of the end of the clutch slave cylinder? Its a simple ring with no ears on it like a regular snap ring so I have not been able to use snap ring pliers. I've been trying to get a small screwdriver under it and it seems there must be a better way....
1977 712
1977 712
pinzdriver
slave cyl lock ring
I use a sharp small screw driver
tony in az 73 pinz 6X6
pinzdoctor is the name,pinz repair is the game!
Slave Cylinder Ring
Thanks Tony,
I let is soak with some penetrating oil overnight. Then I put it in a vice and was able to get it with a little screwdriver. Thanks for your response.
1977 712
1977 712
