Exc. II differential spider gear whos got them?
cruzoropeza
Post by cruzoropeza »
im want to see if anyone sells the kit? i found a company that sells them but they have to install kit.(mogsrus) there starting price is 5gs which i think most of it is for labor im assuming. thanks for you feed back!
Re: Exc. II differential spider gear whos got them?
SAV sells all the parts you would need but not as a kit. They could probably tell you what pieces you need. Scott at EI probably has them also.
Keep in mind the entire differential has to be disassembled to install the new gears - not a simple task.
Labor may be a large portion of the amount quoted but the parts cost is significant.
Good luck!
Call Scott or SAV. As for installation, PM me for a reasonable time $ estimate if you are interested.
I have done several of these kits.
