Transmission Input shaft
Posted: Thu Jun 16, 2011 10:54 pm
by rospaw
Trying to get my parts ordered. I have to change out the input shaft on the transmission due to a grove that has warn in it. Noticed it when i pulled the clutch. When changing this shaft what other parts (gaskets, seals ect) do i need? Thank ahead...... Shawn
Re: Transmission Input shaft
Posted: Thu Jun 16, 2011 11:06 pm
you might be able to use a repair sleeve if proper size is avalible.
http://www.vsm.skf.com/en-US/HeavyDuty/ ... leeve.aspx
Ed
Posted: Fri Jun 17, 2011 11:04 pm
by pinzdriver
You will have to split the trany case to replace the input shaft and take it from me you dont want to open up that can of worms. :oops:
Posted: Sat Jun 18, 2011 12:37 am
by cruzoropeza
been there take it a step at a time! your lucky you know where the problem is, one of my transfer gave out in my pinz and i could pin point where the problem was i ended up taking it all apart to find the problem!
Posted: Sat Jun 18, 2011 2:12 am
by rospaw
cruzoropeza wrote:been there take it a step at a time! your lucky you know where the problem is, one of my transfer gave out in my pinz and i could pin point where the problem was i ended up taking it all apart to find the problem!
Man that looks like a project from .....! :lol: I don't mind spilting the case (been in a tranny or two) but sure would like to know gaskets, seals ect that i will need and a few i might need. When doing it i would like to tear down and build it back in the same eve. Keeps thing fresh on where they go-went-might fit :roll:
Posted: Mon Jun 20, 2011 5:50 pm
rospaw I sent you a PM check your messages
