Leaking Carbs
Leaking Carbs
Both carbs have started leaking badly through the upper gasket. Coincidence or could there be a common cause?
Re: Leaking Carbs
If they're the same age they could fail at the same time, I suppose. What are the gaskets made from?
Robin
Pinzgauer 710K
MegaJolt ignition
(upgrading to MicroSquirt)
Robin
Pinzgauer 710K
MegaJolt ignition
Re: Leaking Carbs
I don't know what they're made from but I had a minor leak a couple of years ago and replaced the gasket so they're not the same age.
Winter Beater
Re: Leaking Carbs
loose screws from vibration or bad float valves causing the bowl to over fill?
