Upgrading TGB 11 lights
- bababiscuit
Howdy all, I'm new to the forum. I have 75 TGB 11 which I am currently sanding and repainting, I will be posting before and after photos soon enough. When I removed the front indicator lights ( above headlights ), the housing was rusted out and I am faced with replacing the Hella units ( K232735 ). I am hoping to upgrade to LEDs, and am hopeful for any input y'all might have to offer...thanks----Erik
Re: Upgrading TGB 11 lights
I would try to find stock units. Using something else usually messes with the look and will kill resale value because you will likely have to cut metal and the next person wont want them regardless. They are very hard to find but do exist. Maybe Claes has some. ?
Also, using LED's may require modifying the blinker relay unless they are made for retrofitting.
- bababiscuit
Thanks for the input, Vince, good to know...got the LED idea from your red C303 restoration tail lights...I will contact the Swedish link you provided for parts to see what they have available-----cheers, Erik
Yeah I wish Hella made some LEDs for the front that would match up in some way. I was lucky and got new front signals while in Sweden. I used to have a few extra but sold them long ago.
- bababiscuit
Yeah, those NZ lights you fabricated onto yer red one sure were nice...I'll check with the Swedes...thanks-----Erik
wrangler_tj
The originals are still on stock. You can buy new ones and put a H4 lamp in it.
Then you have 50/66watt but a lot more light than the round original ones.
We are talking about the amber signal/turning housings, not the headlight.
