Bleeding brakes not giving me any results
cruzoropeza
Post by cruzoropeza »
I keep bleeding brakes but I still have to double pump in order to get good stoping power what should I be checking? Thanks in advanced!
Re: Bleeding brakes not giving me any results
Recommend adjusting the shoes, really not a difficult thing. Took me awhile the first time but once I found out that the two threaded holes are for bolts
that remove the drums it was a cinch. I am sure that others will chime in if you have questions. Also a great time to clean everything out...wear a dust mask
that dust is not good for you.
I had your same issue...that's how I know.
cruzoropeza
I'll try that out thanks!
Air will just give you a spongy feeling. Like krick3tt said, adjusting shoes will likely solve having to double pump but you might need new shoes if you lost too much material, or in a more extreme case, new drums if that doesn't work and they look worn or have been turned down once already.
cruzoropeza
Hopefuly it's just an adjustment I'll check it oit when I return home next week!
spandit
Post by spandit »
I had exactly this and it was the shoes that just needed adjusting. Give them a good clean whilst you've got the drums off
Robin
Pinzgauer 710K
MegaJolt ignition
(upgrading to MicroSquirt)
cruzoropeza
Thanks for the link!
totaljoint
Post by totaljoint »
I was amazed at how much sand/grit accumulated in my brake cylinders when I took them apart. Driver side front was
completely clogged up.
Big difference in the braking ability and firmness of pedal when I cleaned and flushed them.
Ed
spandit
Post by spandit »
I generally power-hose mine when I take the drums off after off-roading - the pile of crud that drains out is quite something. I also give the pads a scrub with a wire brush and then spray with brake cleaner to get any grease off
Robin
Pinzgauer 710K
MegaJolt ignition
cruzoropeza
I finally got around to adjusting the brakes and it worked!!!! Thank you all for your tips its like day and night!!!!
