Chirping Noise
Chirping Noise
I occasionally get a chirping noise that turns into a screech that seems to be coming from the transfer case area or maybe the right rear hub. Anyone have any thoughts on this? I'll be changing all fluids this weekend and will check the wheel bearings while I'm at it. It sounds very much like a slipping belt, which I did change last weekend and will check tension on again as they do tend to stretch initially. I'll update either way. Thanks -Steve
- bonefish635
Re: Chirping Noise
It's not by any chance a bird's nest?
That would certainly explain the chirping and I could well imagine circumstances during driving which would so alarm a clutch of young birds that they might begin to screech.
Hope that's helpful.
T
T
1973 710K
2001 Landcruiser Amazon
2007 Range Rover Vogue (sold)
Re: Chirping Noise
sounds like a clutch throwout bearing to me......
Bernhard
1975 710K
2013 Tacoma TRD 4X4
1975 710K
2013 Tacoma TRD 4X4
Re: Chirping Noise
Ya know, now that you mention it, it does sound like that kind of noise, but would that happen with the clutch engaged?
I seem to get it more when getting on the power and when starting out cold. I even thought it might be a harmonic setting something off but, as stated earlier, it seems to be from that right rear although on a Pinz that could emanate from anywhere. I'll play with the clutch idea... Thanks
