I have looked through the manual and it tells all about the tranfer case but nothing about the simple stuff.
Jer
Where the Tranfer case fluid level check?
Jerbearyukon
czarthirteen
Re: Where the Tranfer case fluid level check?
Upper plug.
Pinzgauer 712AMB
VW Passat GLX 4motion wagon
Triumph Sprint ST Executive
1986 VW Golf Diesel (AAZ diesel motor, Quattro drivetrain)
Jerbearyukon
I am used to that in a pinz....I was just wondering where abouts it is. Guess I will see when I get under there.
Can't use tha hoist at the college anymore so that sucks
jer
jer
Fill plug is next to front output flange. Grab the flange with trans and t case in neutral, if it has up and down play you have found your problem. Plan on replacing the high input gear and the slide sleeve.
Jerbearyukon
Thanks Jim....
I will pass it on to my buddy
Jer
Jer
