Where the Tranfer case fluid level check?
Posted: Wed Apr 25, 2012 1:17 pm
by Jerbearyukon
I have looked through the manual and it tells all about the tranfer case but nothing about the simple stuff.
Jer
Re: Where the Tranfer case fluid level check?
Posted: Wed Apr 25, 2012 1:54 pm
by czarthirteen
Upper plug.
Posted: Wed Apr 25, 2012 2:10 pm
by Jerbearyukon
I am used to that in a pinz....I was just wondering where abouts it is. Guess I will see when I get under there.
Can't use tha hoist at the college anymore so that sucks
jer
Posted: Wed Apr 25, 2012 7:13 pm
Fill plug is next to front output flange. Grab the flange with trans and t case in neutral, if it has up and down play you have found your problem. Plan on replacing the high input gear and the slide sleeve.
Posted: Wed Apr 25, 2012 9:35 pm
by Jerbearyukon
Thanks Jim....
I will pass it on to my buddy
Jer
