interesting product
Posted: Tue May 22, 2012 9:53 pm
by 4x4Pinz
For those who drive, these little vibration traps we all call pinzgauers, a lot and have the exhaust bolts loosen up. Has anyone tried these lock washers
http://www.nord-lock.com/default.asp?url=2.16.37
I have fought exhaust bolts loosening up ever since I bought my pinz in '04. Am getting real tired of buying the studs, washers and nuts. The new stainless version SAV sells work OK but I still loose a few every now and again.
Going to pick up a few of these and see how they work unless someone has tried them with no luck.
Re: interesting product
Posted: Tue May 22, 2012 11:15 pm
I used them on another project where I kept having bolts loosen up and they worked well. I haven't had the problem you mentioned with the exhaust bolts. Just lucky I guess.
I got the NORD-LOCs from McMaster-Carr here: http://www.mcmaster.com/#standard-lock-washers/=hnjfoa
Let us know how they work out.
Posted: Wed May 23, 2012 9:23 am
by berger
Cool.
I know nylocks are probably out, due to the heat, but would a prevailing torgue nut not work too? I used one when I did the "doo" on my KLR, and it was a critical part.
Posted: Wed May 23, 2012 1:28 pm
by Dreadnought
In the good old days we would drill the bolts and wire the nuts on.....they might come a little loose but could not fall off.
