New Speedo and Fuel Guage for 710K
mm58
Post by mm58 »
Wondering what the price & availability would be to get a new speedometer and fuel gauge for a 710K. (OEM european style)
Re: New Speedo and Fuel Guage for 710K
New OEM speedometer runs about $450 if you can find one. SAV is out of stock. I would check with Scott at EI.
Original fuel gauges are even harder to find. Most switch to the current VDO unit.
Are your's missing, or just not working?
I got the aftermarket fuel gauge from SAV and it looks fairly original.
mm58
Post by mm58 »
undysworld wrote:Are your's missing, or just not working?
Just not working...
Here's the VDO gauge SAV sells: http://www.pinzgauer.com/showdetails.ph ... no=SAV1400 It's a direct replacement IIRC, although I'm pretty sure it uses a trim ring because it's a hair smaller diameter.
What's the matter with your speedo? They're pretty easily fixed in most cases. There are a few write-ups if you search, or I can perhaps answer your questions about it, or as a last resort you may want to send it my way and I'll see if I can fix it for you. It's about a 1-2 hr. job usually. I've done several.
crcpinz
Post by crcpinz »
Maybe you need to earth the fuel sender and get a new speedo wire. Most things in the pinz are easy fixes. Do a search.
Si vis pacem, para bellum
1976 710K
mm58
Post by mm58 »
Unfortunately, I have no specifics on what is wrong with the speedo and fuel gauge. I'm just told "they don't work".
I test drove it yesterday, and yes, I did observe that they did not function.
It'd be great if they just needed a new cable or just to be grounded
Excellent rundown on the fuel gauge Edzz. I was unaware that existed. Thanks for the link.
