exhaust stud spec on 710k engines question
Posted: Sun Oct 07, 2012 5:13 am
by bonefish635
Anyone know the specs of Pinzgauer exhaust studs? I assumed they were standard metric M8 thread but they don't seem to be.
Buying SPD replacements here seems tricky/ very slow, and so I was looking at sourcing equivalent parts.
Any help gratefully received, as always.
Tony
Re: exhaust stud spec on 710k engines question
Posted: Sun Oct 07, 2012 5:31 am
by bonefish635
Is it in fact M8x1.25?
Posted: Sun Oct 07, 2012 11:56 am
by edzz
from spare parts catalogue
Posted: Sun Oct 07, 2012 1:20 pm
by Jim LaGuardia
Yes they are 8mm x 1.25 thread pitch, make sure to use a hardened stud.
Posted: Sun Oct 07, 2012 5:11 pm
by bonefish635
I found advertised stainless studs with inset hex drives for stud insertion.
Any problems going with stainless studs? They come with stainless bolts too. I notice the Pinz ones are brass. I'm guessing there's a good reason for that but I amn't technical enough to know straight off what that is.
Posted: Sun Oct 07, 2012 9:57 pm
by edzz
bonefish635 wrote:I found advertised stainless studs with inset hex drives for stud insertion.
Brass? Don't think so, touch one to a grinder, sparks its steel. 8)
Posted: Mon Oct 08, 2012 3:04 pm
by bonefish635
It's the nuts that are brass. I was wondering what the reason was for that metal choice?
Posted: Tue Oct 09, 2012 10:29 pm
by Jim LaGuardia
To keep from rusting/galling.
Use a std 8.8 rated stud with brass nut and seat washer. (these will not loosen when hot)
Posted: Wed Oct 10, 2012 1:44 pm
by bonefish635
Thanks Jim.
