exhaust stud spec on 710k engines question
bonefish635
Post by bonefish635 »
Anyone know the specs of Pinzgauer exhaust studs? I assumed they were standard metric M8 thread but they don't seem to be.
Buying SPD replacements here seems tricky/ very slow, and so I was looking at sourcing equivalent parts.
Any help gratefully received, as always.
Tony
1973 710K
2001 Landcruiser Amazon
2007 Range Rover Vogue (sold)
bonefish635
Re: exhaust stud spec on 710k engines question
Is it in fact M8x1.25?
1973 710K
from spare parts catalogue
Yes they are 8mm x 1.25 thread pitch, make sure to use a hardened stud.
bonefish635
I found advertised stainless studs with inset hex drives for stud insertion.
Any problems going with stainless studs? They come with stainless bolts too. I notice the Pinz ones are brass. I'm guessing there's a good reason for that but I amn't technical enough to know straight off what that is.
1973 710K
bonefish635 wrote:I found advertised stainless studs with inset hex drives for stud insertion.
Brass? Don't think so, touch one to a grinder, sparks its steel. 8)
bonefish635
It's the nuts that are brass. I was wondering what the reason was for that metal choice?
1973 710K
To keep from rusting/galling.
Use a std 8.8 rated stud with brass nut and seat washer. (these will not loosen when hot)
bonefish635
Thanks Jim.
1973 710K
