How noisy is the BN4 fan supposed to be?
mm58
Post by mm58 »
My BN4 heater seems to work fine, but the fan (to me) seems a bit noisy. Like a loud buzzing sound.
I've already eliminated the fan blades themselves (rubbing) as the cause.
Is it normal for this heater to be this noisy? I have no other experience with these heaters to compare with.
NoahDL88
Re: How noisy is the BN4 fan supposed to be?
Post by NoahDL88 »
If I put a little pressure on the case mine quiets down quite a bit. Just some buzzing between metal parts, I'm not worried about mine, but it is annoying at times.
1972 710K
Roverchef
Germany
Post by Roverchef »
I've never heard of a completely quiet one before.
mm58
Post by mm58 »
Jake, check your inbox. I've sent you a couple of PMs but did not hear back from you
