Reverse Gear Potential Issue
Posted: Mon Dec 03, 2012 10:20 am
by khansmith
Hello,
My pinz is getting delivered today and the driver of the transport said that he was unable to get it into reverse. I have never driven a pinz before so I thought I would reach out here to see if anyone could shed some light on the issue in case there might be a simple thing he has overlooked.
Regards,
Khan
Re: Reverse Gear Potential Issue
Posted: Mon Dec 03, 2012 10:40 am
It might be as simple as the driver is neglecting to push down on the shift knob before attempting to shift into reverse. This is a lockout to prevent inadvertent shifts from first to reverse.
Posted: Mon Dec 03, 2012 10:42 am
Shifts just like an old VW.
Posted: Mon Dec 03, 2012 10:55 am
:shock: It is most likely that the truck driver simply never learned to drive a manual transmission, so common now with people being brought up on automatic transmissions.
That said it could be (amongst other less probable things) bad shift bushings, a cheap and easy fix.
Even if it turns out that the driver simply doesn’t know his as from a hole in the ground I’d recommend inspecting these bushings and ordering a set for your field spares kit. See the following thread.
viewtopic.php?f=13&t=6426&hilit=bushing
Posted: Mon Dec 03, 2012 11:22 am
by khansmith
Wow! You guys are fast! He didn't sound to bright so I hope it is just user error. I'll know later today.
Posted: Mon Dec 03, 2012 11:54 am
by bonefish635
I find reverse is best found from first. On my '73 710K it isn't straight ahead of 1st (as the diagram suggests) but slightly to the right of straight ahead.
Once you've found it a couple of times, you won't miss it again.
Tony
Posted: Mon Dec 03, 2012 12:05 pm
by mm58
bonefish635 wrote:I find reverse is best found from first. On my '73 710K it isn't straight ahead of 1st (as the diagram suggests) but slightly to the right of straight ahead
Tony
+1 on that!! I was having a hard time getting into reverse without crunching gear teeth. Almost every time. Then I read a post about how the rev gear isn't syncro'd like the rest or the forward gears, and that by going into first (or any forward gear) first, and then quickly shifting into reverse, you'd avoid that crunch. WORKS LIKE A CHARM! I can now get into reverse like butter!
Posted: Mon Dec 03, 2012 1:12 pm
And often the reverse "gate" (that requires the downward push to engage reverse) is not necessarily well adjusted. It is easy to understand with two people: one to sit in the seat and work the shifter, and one (you) to lie on the ground and see what is going on at the bottom of the shifter. It is right under the floor panel and easily visible when underneath, but you need to see the shift lever motion to really grasp what is is and what it does. Have your helper work the lever from first to neutral, then push down, then try to engage reverse. You will see how it works. Loosen two bolts and you can adjust the gate to work easily, tighten the two bolts and you are done.
This was one of the first fixes that I ever did to my truck, and it has never needed adjusting again.
Posted: Mon Dec 03, 2012 2:42 pm
by totaljoint
Two pushes on the clutch before shifting into reverse eliminates the "grinding" on mine.
Posted: Mon Dec 03, 2012 3:14 pm
by khansmith
OK...works just fine. The driver didn't understand the instructions from the previous owner and has never been in a classic VW either. Got her home just fine. Funny....as he was pulling it off the truck, an ambulance came up and started asking lots of questions. Figure that will be normal from now on. Fun to drive! Although she needs new tires really bad. A bit of dry rot!
Posted: Mon Dec 03, 2012 4:05 pm
by mm58
khansmith wrote:... Figure that will be normal from now on. Fun to drive! ...
Everytime you go out in it, there will be heads turning, mouths agape, fingers pointing, and lots of questions!
Posted: Mon Dec 03, 2012 4:37 pm
by djw
khansmith wrote:started asking lots of questions. Figure that will be normal from now on.
It is a people magnet in the daytime. If you go out much at night and haven't repainted, you're a bit less visible. Not much either.
Posted: Mon Dec 03, 2012 6:55 pm
by crcpinz
Funny to read a thread in which I agreed with everybody, although it's not the first one. Now you need to read a lot about tires, my first and only mod., before you decide on a size/tread. Good luck with your new truck. Hope you enjoy it as much as everybody on this forum.
Posted: Mon Dec 03, 2012 7:59 pm
khansmith wrote: Funny....as he was pulling it off the truck, an ambulance came up and started asking lots of questions. Figure that will be normal from now on.
And you thought "UDF" was bad :lol: :lol:
For the Pinz guys, UDF is foil head slang for “Ural delay factor”.
Posted: Tue Dec 04, 2012 7:56 am
khansmith wrote:OK...works just fine. The driver didn't understand the instructions from the previous owner and has never been in a classic VW either. Got her home just fine. Funny....as he was pulling it off the truck, an ambulance came up and started asking lots of questions. Figure that will be normal from now on. Fun to drive! Although she needs new tires really bad. A bit of dry rot!
Pics - need to post some pics!
