It's that time, and I am thinking about my frozen ends...feet and elsewhere. Just found this and thought I would pas it along.
http://www.sportsimportsltd.com/24v-or- ... s-kit.html
Its 24V so I expect there is no great issue with fitting it in to a pinz.
seat heaters
seat heaters
Re: seat heaters
Looks like a good kit at a reasonable price - but the current draw isn't correctly listed:
Electrical Specs: Wattage: 36 Watts per Pad,72 Watts per seat Current Draw: 1 Amps on Low Heat Setting and 1.5 Amps on High Heat Setting.
I think the current listed is per pad - so double for a seat. The pads are small enough that you could fit three or even four in a seat for really cold conditions....
I might go for a set of these.
