Page 1 of 3
Rear bumper
Posted: Fri Jan 04, 2013 12:49 am
by westernair
As I wait for my engine to come back for my hafi from Leonardo, I have decided to build a rear bumper for the Pinz.
So far I have only cut the bulk metal. This weekend I will begin the fabrication. Should weigh 65 lbs w/o the tire carrier.
I am using 1/4 inch 4x6 square tubing as it will allow for the 2 inch hitch to pass through it when connected to where the pintal was, the 1 3/4 DOM will be welded to where the stock braces come off the truck. Mounting points will be the 4 stock bolts below the rear door, the pintal bolts and the stock side braces. I will also at some point weld a s swing arm pivot into it for a swing out tire carrier.
- ImageUploadedByTapatalk1357281647.112816.jpg (39.62 KiB) Viewed 8085 times
- ImageUploadedByTapatalk1357281666.434558.jpg (77.63 KiB) Viewed 8085 times
- ImageUploadedByTapatalk1357281692.262042.jpg (35.54 KiB) Viewed 8085 times
Re: Rear bumper
Posted: Fri Jan 04, 2013 12:54 am
by westernair
I just did this this last post with pictures using tap talk. Retry easy from my phone while standing in the garage!
Re: Rear bumper
Posted: Fri Jan 04, 2013 10:57 am
by Haf-e
So are you going to tie the body to the drivetrain then? If it connects to both the pintle tow mounts and the stock rear bumper "tubes" then that would allow a lot of vibration to be conducted and also might result in stress cracks etc???
Re: Rear bumper
Posted: Fri Jan 04, 2013 11:15 am
by westernair
So best to go to just the stock mounts? Thats fine it will make it easer.
Re: Rear bumper
Posted: Fri Jan 04, 2013 11:29 am
by westernair
For those that have asked, or dont remember, the front bumper fabrication is here
viewtopic.php?f=18&t=6881
I know the rear is not of the same design as the front, but this one will go together comparably quick
Re: Rear bumper
Posted: Fri Jan 04, 2013 12:30 pm
Keep the hitch mounting and the bumper separate.
Re: Rear bumper
Posted: Sat Jan 05, 2013 3:56 pm
by westernair
Re: Rear bumper
Posted: Mon Jan 14, 2013 1:03 pm
by westernair
Weekends have been busy with non-Pinz stuff but during the evenings I have been still working on the bumper replacement. As you can see the blade is finished, now I need to cut the square hole for the 2 inch recever, make the spare tire mount, and weld on the upright bars.
My question now is where should I mount the hinge pin for the tire mount. Anyone have some experience with this and want to share? Also pics of the swing arm would help.
- ImageUploadedByTapatalk1358190148.372281.jpg (51.53 KiB) Viewed 7839 times
- ImageUploadedByTapatalk1358190168.717072.jpg (39.38 KiB) Viewed 7839 times
- ImageUploadedByTapatalk1358190190.585382.jpg (39.38 KiB) Viewed 7839 times
Re: Rear bumper
Posted: Mon Jan 14, 2013 1:04 pm
by westernair
- ImageUploadedByTapatalk1358190249.873362.jpg (32.85 KiB) Viewed 7838 times
One more
Re: Rear bumper
Posted: Mon Jan 14, 2013 1:21 pm
by westernair
I also may upgrade my backup light to lights mounted in the bumper.
Re: Rear bumper
Posted: Mon Jan 14, 2013 9:14 pm
by M Wehrman
The bus in the backround looks interesting....
Re: Rear bumper
Posted: Tue Jan 15, 2013 12:45 am
by westernair
M Wehrman wrote:The bus in the backround looks interesting....
Just another air cooled toy.
Here are a few pics of it at a photo shoot last year, if you are interested
http://www.griotsgarage.com/text/conten ... hb333.html
Re: Rear bumper
Posted: Tue Jan 15, 2013 1:49 pm
by westernair
Bumper swag. 1/4 plate plasma cut
Re: Rear bumper
Posted: Tue Jan 15, 2013 2:17 pm
by mopar
Very nice I like it the bumper and badges wish I had those fab skills.
Re: Rear bumper
Posted: Tue Jan 15, 2013 4:53 pm
by westernair
mopar wrote:Verry nice I like it ot wish I had those fab skills.
If people wanted some of these Pinzgauer name plates, I could produce them for $30 a pair.
