Crimping Rubber rope for the top.
Posted: Tue May 07, 2013 7:56 pm
by mopar
Looking to replace the rubber rope on the top. Can some one school me on how to crimp the clamps on the ends? I saw one recomendation for mcmaster car clamps but can't find how to clamp them.
If you could post pics I'd apreciate it as I am very visually oriented and would like to select my method by tidiness and holding power. I tried googleing and search in the forum with no luck. Cold War says to call for their method and not to buy the tool but no one answers.
Thanks in advance!!
Re: Crimping Rubber rope for the top.
Posted: Tue May 07, 2013 9:18 pm
I seem to recall that someone mentioned that tile nippers work well for crimping the ss clamp rings. I use a pair of Channelock cutting pliers I had around like these:
I have to be careful with them since they will cut thru the clamp if squeezed too hard.
Posted: Wed May 08, 2013 3:20 am
by David Dunn
The end nip pliers crimp the cleanest, but almost any pliers will accomplish the same, even dices. But as Paul said, be careful on the pressure used
Posted: Wed May 08, 2013 7:43 am
Google Oetiker
You can never have to many tools :)
http://www.amazon.com/Oetiker-18500056- ... s_indust_5
Posted: Tue May 14, 2013 6:09 pm
by mopar
OK got my clamps and tile nippers and dulled them a little. Any one have a picture of of a crimped clamp? do I just crimp the 2 ears or do I crimp the middle?
Posted: Tue May 14, 2013 6:44 pm
by audiocontr
I just use channel locks and squeeze.
Posted: Tue May 14, 2013 7:43 pm
I crimp the 2 ears and then squeeze the center area with channel locks if needed.
Posted: Tue May 14, 2013 8:00 pm
by mopar
OK got it figured out Muttandjeeps sent me a picture. Thanks
Posted: Mon May 20, 2013 6:39 am
by mopar
Some pictures of the crimps for future reference as I did not have and of these clamps on my rig to go by.
Posted: Mon May 20, 2013 8:11 am
Just for archive: how did you end up crimping?
Buy the tool, Channel Locks or did you use the tile nippers?
Crimps look good!
Posted: Mon May 20, 2013 9:07 am
by mopar
I used a pair of pincer pliers from Lowes crimped the ends first and then the middle. I dulled the plier ends up a little on the sander first so I wouldn't cut through the clamps.
http://www.lowes.com/pd_284107-16878-53 ... s_dollar|1
Posted: Fri Mar 28, 2014 8:52 pm
by Pinz710m2
I'm looking to buy some of the crimps and I've already got the rubber rope.
I went with 3/8 inch rope which is just a hair bigger than what's on there
now. But what size crimps do I buy??? Is the 3/8 in crimp meant for
crimping 1 3/8 inch rope, or 2 ropes? Should I get a larger size, say 3/4 inch? (2 x 3/8)
Posted: Sat Mar 29, 2014 6:52 am
by crcpinz
I ordered rubber rope but it came in two pieces. What's the best way to crimp them together? I don't have clamps, so I'm thinking of simply tying them together with copper wire tightly wound.
Posted: Sat Mar 29, 2014 7:15 am
by mopar
Pinz710m2 wrote:I'm looking to buy some of the crimps and I've already got the rubber rope.
I used 3/8s as well and just used the stainless clamps from SAV.
Posted: Sat Mar 29, 2014 8:31 am
by Pinz710m2
If you want to connect the two ropes together, use a crimp on
the end of each, and a stainless ring, just like on the ends.
