Not running right, lots of soot, backfiring through carbs
I had an extremely difficult time starting the pinz one day after a heavy rainstorm. I figured it was a mix of the carbs needing new gaskets and moisture in the distributor.
I cleaned out the moisture and rebuilt the carbs.
The truck started quickly! No need to pull a choke. I adjusted idle to where it was a little lobey and it seemed to rev well. Timing at 5 degrees btdc. Test drive created HUGE backfire out of both carbs, no acceleration, and a difficult time shuttiong down (both carbs smoked for a few seconds after shutting down).
I popped off the cap and its FULL of oily soot as well. Is it sucking it up through the engine?
1) Will the truck run if i placed the distributor in 180 degrees out of sync?
2) Why would there be oil residue inside the cap?? Contacts seem very scorched/burnt
3) What causes the exhaust to create soot? too much fuel? I have the external mixture screws, each turned out 1.5 turns and a decent 900 rpm idle
Re: Not running right, lots of soot, backfiring through carb
add more detail
Mixture jets all the way in - Runs better. Idle screws all the way out - doesnt stall!!!
I messed up something.
Do the butterflies have a up or down side? They can go on 4 ways theoretically. Does it matter?
spandit
Post by spandit »
Soot indicates truck running too rich (i.e. too much fuel or not enough air) - have you cleaned your air filter lately?
Have you checked the levels in the float chambers? If you "rebuilt" the carbs then you might have damaged the floats or made them stick...
Robin
Pinzgauer 710K
MegaJolt ignition
(upgrading to MicroSquirt)
Butterflies were upside down. =)
McCall Pinz
Post by McCall Pinz »
Did you see what I meant about the angled edges? :?
eat, sleep, Pinzgauer
Yup, sure did. I'll need to replace them now I think.
