How the heck...
How the heck...
Do your remove this bracket for the front skid plate?
The center bolt is simple but then there are 2 bolts behind the threads of the rubber bushings.
The bracket is so small and tight that I see no way to remove the rubber bushings.
Chicken and egg sort of thing.
Pulling my hair out about this one as wrench will not even fit on bushing bolts as there is no space.
My next step is to rip up whats left of my rubber bushings and then try to cut or drill them out to get to bolts behind!
- SkidPlateRearBracket.jpg (51.92 KiB) Viewed 8899 times
rustywheel2004
Re: How the heck...
Hi Dan,
You must unbolt the rubber anti-vibration mounts from the bracket then the nuts on the center tube flange can be accessed. It's a tight fit for the wrench but it's doable. I have Snap-On Tools wrenches that have heads which are smaller than most manufacturers so this made the process a bit easier.
Steve
Steve
1971 NA 700AP
Re: How the heck...
Was at one shop today looking for smaller head wrenches
Did not find anything but will check with some friends and see
It is a crazy tight fit (I have less than 1/8 of an inch to move and that is 'if' I get the wrench to grab!
Will post a victory post if I get the rubber mounts off
Thanks Steve
Thanks Steve
Re: How the heck...
You need a Ural tool kit!!
The ural wrenches have really flat heads that I use on things that a standard box wrench won't reach.
You might try Princess Auto. Tool won't break the bank and many options.
Sent from my Mobile
Sent from my Mobile
sixbennetts
Re: How the heck...
Go buy a cheap wrench at Wally-World and grind it flat. Shouldn't take more than 10 minutes with a new grinding pad.
Re: How the heck...
I haven't got a skid plate on mine...
Robin
Pinzgauer 710K
MegaJolt ignition
(upgrading to MicroSquirt)
Robin
Pinzgauer 710K
MegaJolt ignition
rustywheel2004
Re: How the heck...
Hey Robin,
You might want to get yourself a front skid pan as they are principally responsible for structural support to the front footwell section. Without the pan the front section will eventually sag due to the minimally supported weight of the tub, steering box and driver..
Steve
Steve
1971 NA 700AP
Re: How the heck...
I did not know you had a Haflinger!spandit wrote:I haven't got a skid plate on mine...
Ok I have 3 plans of attack:
1. 18mm offset box head
2. 18mm angled box head
3. Cheap 18mm I can grind down if 1 and 2 don't work
Will report this afternoon
Re: How the heck...
Ah, that clears things up then!TechMOGogy wrote: I did not know you had a Haflinger!
Robin
Pinzgauer 710K
MegaJolt ignition
Robin
Pinzgauer 710K
MegaJolt ignition
Re: How the heck...
Victory (but it was 17mm
Issue was also that someone put new ones on and the threads were so tall they hit the center tube so could not get box wrench 'over'
- ImageUploadedByTapatalk HD1370118967.125442.jpg (19.1 KiB) Viewed 8827 times
- cascade.king
Re: How the heck...
My friend had a vehicle with bolts set like that. The previous owner tightened them on, then cut the handle off the wrench. Coated in greese and dirt, looked ok...
Nice fork, er, wrench.
