Hello folks!, i just found this little oil leak on my transmission, and im hopping that you guys can tell me if this is a simple repair, i was hoping to be as simple as desconnecting the linkage and slide out n slide in a new seal... now, is this seal a regular seal?? should i remove it and go look for the same, or somebody here know the specs for this seal???? here some pics..
1985 710MS
1985 712MK
Should be pretty easy to remove the shifter housing and remove the selector shaft to put a new seal in properly. Not sure if it's an O-ring or a seal or both.
I also have that leak. It doesn't drip at all while the vehicle is stationary even after several days, but if I clean it up and go for a drive it's wet again. Keeping an eye on the oil level...
Sorry no pics but I did get around to fixing mine. Not much to it if you have Andre holding your hand. I'm sure he gets tired of me calling. Pop out the little rubber plug on top if the tower and rotate the shaft till you see two roll pins thru the hole. Drive them out with a punch. Don't lose them. Once they are out you can slide the shaft out. It takes some pulling so don't be afraid. It won't just fall out. Once the shaft is out you can remove the seal. Mine only had one in it. Luckily the one I ordered was the thinner inner seal, so I popped out the thicker one whic was still in decent shape. Popped the thinner one in and put the other thicker one in last. Slide the shaft back in and line up the holes making sure the arm is pointing down ( I know that should be a given but I had to do over cause I put it in upside down the first time) drive in the large roll pin then the small one replace the base gasket( I made mine cause I forgot to order one) and bolt back on the truck. Done. If I can do it anybody can.
Ok here we go, lots of pics but overall a very simple job.
First remove your tranny although not necessary it makes the job a lot easier.
Shifter Rebuild.jpg (29.57 KiB) Viewed 9823 times
2. Drain oil
3. With a 13mm socket remove the shift tower (5 bolts)
Shifter Rebuild_2.jpg (29.94 KiB) Viewed 9823 times
Shifter Rebuild_3.jpg (31.01 KiB) Viewed 9823 times
4. Once removed use a blade driver and gently pry out the plastic stopper(you may have to work at it a bit)
Shifter Rebuild_5.jpg (28.32 KiB) Viewed 9823 times
5. You should now see the 2 dowel pins that you will have to remove(one inside the other). Drive both of them straight down with a small punch one at a time until they fall out the bottom side
Shifter Rebuild_6.jpg (26.74 KiB) Viewed 9823 times
