tranny oil leak....
Posted: Wed Jul 10, 2013 10:43 am
by waterdog
Hello folks!, i just found this little oil leak on my transmission, and im hopping that you guys can tell me if this is a simple repair, i was hoping to be as simple as desconnecting the linkage and slide out n slide in a new seal... :roll: now, is this seal a regular seal?? should i remove it and go look for the same, or somebody here know the specs for this seal???? here some pics.. Image Image
Re: tranny oil leak....
Posted: Wed Jul 10, 2013 12:15 pm
by Stekay
Should be pretty easy to remove the shifter housing and remove the selector shaft to put a new seal in properly. Not sure if it's an O-ring or a seal or both.
Posted: Wed Jul 10, 2013 6:07 pm
There are 2 seals(and a tower mounting gasket), get the numbers from the parts manual or order them from one of the forum sponsors.
Posted: Wed Jul 10, 2013 9:06 pm
by waterdog
Thank you guys!!
Posted: Sun Jul 14, 2013 5:58 pm
by Mead
Hey Waterdog,
If you don't mind post a couple more pics when you do your repair as I'm 98% certain that I have to do the same repair on my truck.
Thanks :D
Posted: Sun Jul 14, 2013 6:58 pm
by compunerdy
Same here..
Posted: Sun Jul 14, 2013 7:34 pm
by waterdog
i just clean up the area to see how bad is the leak, and has not drip in 2 days, so i guess is a very very small leak, may not get on it too soon :|
Posted: Wed Aug 07, 2013 12:05 pm
by berger
I am certain I have the same leak.
Are these the two seals? 51 and 52
SEAL SHIFTER SHAFT 7101215381/ 02-20-51 8.90
SEAL INNER SELECTOR SHAFT 7101215361/ 02-20-52 7.50
Posted: Wed Aug 07, 2013 1:14 pm
by landy
Same leak as well, but it's such a small volume haven't done anything about it.
Posted: Thu Aug 08, 2013 4:28 am
by Squiggas
I also have that leak. It doesn't drip at all while the vehicle is stationary even after several days, but if I clean it up and go for a drive it's wet again. Keeping an eye on the oil level...
Posted: Tue Sep 03, 2013 11:11 am
by EmbarkChief
I have the exact same leak, was going to post a pic but the OP's picture looks exactly like my situation :D
Posted: Tue Sep 03, 2013 11:20 am
by berger
Someone fix it already and post some pics for the rest of us!!!!! :lol: :lol:
Posted: Wed Mar 12, 2014 8:28 am
by Todd
Sorry no pics but I did get around to fixing mine. Not much to it if you have Andre holding your hand. I'm sure he gets tired of me calling. Pop out the little rubber plug on top if the tower and rotate the shaft till you see two roll pins thru the hole. Drive them out with a punch. Don't lose them. Once they are out you can slide the shaft out. It takes some pulling so don't be afraid. It won't just fall out. Once the shaft is out you can remove the seal. Mine only had one in it. Luckily the one I ordered was the thinner inner seal, so I popped out the thicker one whic was still in decent shape. Popped the thinner one in and put the other thicker one in last. Slide the shaft back in and line up the holes making sure the arm is pointing down ( I know that should be a given but I had to do over cause I put it in upside down the first time) drive in the large roll pin then the small one replace the base gasket( I made mine cause I forgot to order one) and bolt back on the truck. Done. If I can do it anybody can.
Posted: Wed Mar 12, 2014 7:53 pm
by Mead
I also rebuilt mine a couple of weeks ago but took lots of pics...agreed very easy job. I will post some pics next week when I have more time.
Posted: Wed Apr 09, 2014 5:32 pm
by Mead
Ok here we go, lots of pics but overall a very simple job.
First remove your tranny although not necessary it makes the job a lot easier.
Shifter Rebuild.jpg (29.57 KiB) Viewed 9727 times
2. Drain oil
3. With a 13mm socket remove the shift tower (5 bolts)
Shifter Rebuild_2.jpg (29.94 KiB) Viewed 9727 times
Shifter Rebuild_3.jpg (31.01 KiB) Viewed 9727 times
4. Once removed use a blade driver and gently pry out the plastic stopper(you may have to work at it a bit)
Shifter Rebuild_5.jpg (28.32 KiB) Viewed 9727 times
5. You should now see the 2 dowel pins that you will have to remove(one inside the other). Drive both of them straight down with a small punch one at a time until they fall out the bottom side
Shifter Rebuild_6.jpg (26.74 KiB) Viewed 9727 times
