WTB: Amphenol Cannon Plugs
Looking for the right angle version of the MS3106F 20-23P. I think SAV only carries the straight version
It's the 2-pin plug that connects to the J-box behind the passenger seat on a Pinz
I do have one of the straight versions, so for that one, I can get by with just the right-angle section that screws on.
The other two I will need the whole plug.
Any help appreciated
Re: WTB: Amphenol Cannon Plugs
I think what you're looking for is a MS3108. You should be able to determine the full part number you want from the info available here: http://www.milnec.com/mil-spec-connecto ... 15/ms3108/
Mouser Electronics also carries them.
Got mine from SAV. I work for a military contractor and SAV was faster and less expensive.
Gentlemen, thank you for the responses. I believe I know now what part# I need to order.
Stekay, I checked with SAV, and Sarah told me they only carry the straight version (3106)
I'm looking for the right-angle style (3108)
Paul. thanks for the info and the link.
Before I place an order, I'm hoping someone will pop up here that has a couple or three, that they want
to make a few dollars.
compunerdy
Tim, all except for the end. Mine should end with a "P" (for male Pins)
The "S" denotes female Socket.
I know this is not what this tread is about but what is that used for??
Thx
Thx
It's just a j-box connector that, in the "K", routes high amp 24v power through the bulkhead
and into another j-box on the other side. That's where the Army radios would plug into to get their power.
compunerdy
Maybe I am blind but mine only has the box on the back of the partition and not on the front side behind the passenger seat.
Tim
1975 710K
1975 710K
There are as many variations of these trucks as there are uses for them. Not all have everything in the same place.
