Just like the title says, the diff case will not split. I do believe I have all the bolts removed and am not missing anything. I got the case to crack apart but it really does not want to split. All I am trying to do is remove the top cover.
I read this thread as well as anything else I could find on the subject and am not finding anything that helps.
http://www.real4x4forums.com/PinzgauerB ... t&start=45
Are there any tricks to this? The manual simply says, remove cheesehead bolts and tap top of case with a rubber mallet. Well, we have done a lot more than that and it is not coming off.
Here are pictures in case I missed something and you can see that.
We have tapped it and tapped it and tapped it some more. Two people tapping at the same time using wood blocks. It is really stuck and not moving more than what you can see.
Any help would be greatly appreciated.
