Flash and engine dies
Dogslovetrucks
Post by Dogslovetrucks »
New gremlin today. Turn signal flash indicator started randomly coming on approx every 10 seconds, and kills the engine. If I'm running down the street, it just restarts and it's no issue. If I come to a stop and don't rev the engine, it's gone, but starts right back up. No lights on the outside of the truck are coming on when this happens and turning on the blinker/hazzard makes no difference. Electrical is not my strong point, so any help or suggestions are appreciated.
76 710K
Dogslovetrucks
Re: Flash and engine dies
Clarification- the lights on the outside of the truck will come on if I turn them on, but turning them on does not stop the short.
76 710K
EmbarkChief
Post by EmbarkChief »
I can't help on this one but I'm sure someone will chime in soon. I can't wait to hear the answer....
-1972 710M
Buzz
Post by Buzz »
What kind of ignition system are you running? Original points? Petronix?
I would spray out the key switch with electric parts cleaner, I would check the Molex connector on the side of the air tunnel. And I wonder if you have short/loose connection between the key switch and the rest of the system.
1977 712
Dogslovetrucks
Pertronics- I had the molex apart 4 months ago and cleaned but good advise to do it again. Will also try the electrical cleaner as prescribed- thanks!
Last edited by Dogslovetrucks on Tue Oct 29, 2013 3:21 pm, edited 1 time in total.
76 710K
Any popped breakers?
Dogslovetrucks
Success! Ended up being the molex. Thanks for the suggestions and advise!
76 710K
Buzz
Post by Buzz »
Glad to hear it! Intermittent engine problems can be a real pain.
1977 712
