Question - are the lower panels screwed/riveted on or welded in place?
Screwed in place with stainless button head screws, so those panels are replaceable. I love the fact that the jerry can is almost invisible, but still lockable. To get the 43 gallon volume we had to go longer, wider, and deeper - but the tank is still higher than the chassis tube, and the guard is about an inch inset than the outside edge of the rubrails. It has an internal fuel injection pump, with a fuel sock to prevent any crap from getting to the pump (but no red death in this tank!). Still has the heater fuel pickup. Three baffles to prevent fuel slosh. Fuel returns two baffles away from the pump, so any foaming has time to die down.
Andre did an excellent job, the inlet pipe was perfectly centered in the hole in the cab floor. And when I went to mount it I spent only about 20 minutes getting it up and all screws in place, without any help.
