Page 1 of 2
Door near tail light
Posted: Sat Apr 05, 2014 6:18 pm
by Pinz710m2
I'm going against my better judgment and actually asking a
question on this forum. I don't want to hear from anyone that
has no idea what it is, and just wants to venture an uneducated
guess.
Right beside my left tail light, was a small plate with 4 screws.
(and yes, all four screws twisted in half, even after soaking in WD40)
When I removed all 4 screws, I found that the cup was full of dirt
with one wire. Is this the spot for s european style parking light?
Or does it have anything to do with a backup light?
Re: Door near tail light
Posted: Sat Apr 05, 2014 6:56 pm
by krick3tt
Very succinct answer. Now...what activates it? Which fuse or circuit breaker is it on?
Posted: Sat Apr 05, 2014 7:07 pm
by edzz
Posted: Sat Apr 05, 2014 8:25 pm
by crcpinz
Mine has a screw-in receptacle with a cover and chain for a plug of some sort. I don't know its function and have not been able to take the cover off. I guess it must have been for a work light or something similar.
Posted: Sat Apr 05, 2014 9:18 pm
by westernair
Accessory plug like that found on the fire wall of a k. In order for you to use it as a backup light you will need to re-wire it and add the reverse pin available from scott.
Posted: Sat Apr 05, 2014 9:51 pm
by Pinz710m2
So, I guess the question I have is that if I have the backup switch, which I bought from Scott, and I wire
it using the "pink wire" that he details in his instructions, does the pink wire control a relay that, in turn,
controls power to this wire? (Do I hook up the light to this wire and the ground?) I was planning on calling
him because this part was kinda lacking in his instructions.
Posted: Sat Apr 05, 2014 9:59 pm
by Pinz710m2
@crcpinz - If you look behind it you will probably see a cup, with wires
going into the cup. You might be able to follow them back to something
but I would put a voltmeter on it and have someone watch as you press
each circuit breaker. Sounds like someone wired up something custom
on yours.
Posted: Sat Apr 05, 2014 10:04 pm
by edzz
Posted: Sat Apr 05, 2014 10:16 pm
by Pinz710m2
Edzz ... if you don't know the answer, please do not post.
Posted: Sat Apr 05, 2014 10:20 pm
by pcolette
Pinz710m2 wrote:Edzz ... if you don't know the answer, please do not post.
Your answer is in the instructions edzz referenced.
"Simple as can be. In the existing wiring loom is a pink wire that is unused. It runs from the taillights to the Headlight Switch. We use this wire for the reverse lights.
Remove the pink wire from the headlight switch, and connect it to (+) keyed power at the ignition switch.
Beside the fuel tank, just before the wiring loom goes into the steel tube that runs it past the drive shaft, carefully open the loom and pull out the pink wire. Using a weatherpack connector, splice the pink wire to the reverse switch.
In a nutshell, you are sending (+) down the Pink wire to the tail lights. You are splicing that Pink wire at the transmission so that the connection is only made when the transmission switch is shifted into reverse."
Posted: Sat Apr 05, 2014 10:39 pm
by Pinz710m2
Look guys, I'm not asking you to quote what is already out there.
If you don't know the answer, don't reply. The answer is NOT
there. I have several degrees and I can read. Please stop stalking
my posts. I asked a very, very specific question and there is no
reason for you to post unless you know the answer. I said I
wasn't interested in a guess. So please, leave me alone. Go
stalk someone else. Anyone who KNOWS the answer can post.
Posted: Sun Apr 06, 2014 1:11 am
by eToothpaste
Pinz710m2 wrote:So, I guess the question I have is that if I have the backup switch, which I bought from Scott, and I wire
Lets see ... a handful of people read your question and give you the same answer... Perhaps your question could use some revising. It sounds a bit circular to me: A wire that turns on a relay that somehow also supplies the power to the wire?
There's an unused pink wire. Put power on one end, a switch in the middle, and a light on the other end. Chassis is ground. Now, Crack open a cold one using the corner of one of your degrees.
Beers,
Matt
Posted: Sun Apr 06, 2014 1:25 am
by GenevaPinz
Right,
To answer your first question, the wire behind the plate is not related to parking lights (at least from ex-Swiss pinzes' schematics) or backup lights, which were not part of the stock equipment.
On 710Ks, there is in that spot a plug, as mentionned by crcpinz, similar as the one on the front bulkhead of your Pinz, which is related to the truck's batteries. It was used to connect a generator and charge the batteries / power the radios in the 710K from an external source. It is not it in your case as you have a 710M, and the wires would be of bigger diameter.
The pink wire described in Scott's instructions is (off the top of my head) the wire for the convoy lights in the taillights, typically not used during the truck's civilian life, which Scott suggests to re-use for taillights instead of re-wiring.
I don't know if your loose wire is connected to the pink wire eventually or not, and using a voltmeter will tell you straight away.
I hope this helps...
Posted: Tue Apr 08, 2014 9:31 pm
by Andre
The Swiss did have radio M's(I have one). It too has the 24v shore power receptacle (with chain and cap) bolted to the rear left tail light panel.
Posted: Tue Apr 08, 2014 11:49 pm
by Pinz710m2
Thanks Andre. I put the door back for now. This weekend I
might have some time to crawl around and try to trace that
wire backwards using a voltmeter. Seems no one knows with
100% assurance. And mine seems a "standard" 710M. I guess the
most important thing I need to know for my use of that power
source (assuming it is one) is how many amps it can safely handle..
You know, I'm wondering if I put a 3 to 5 amp light on it, will it melt
anything.
I know mine hasn't been used. The compartment was filled with dirt.
