Rear Emergency Flashers
Kaweeka
Post by Kaweeka »
"Everything" works (taillights, turn signals, flashers on the front) but there are no flashers on the back. Any clues on how to track this down? Thanks!
Stuck in the bureaucratic spin cycle!
Re: Rear Emergency Flashers
If the 4 ways only flash the fronts, the 4 way switch assembly will need replacement. The contact board warps or melts preventing signal to rear lamps.
Mead
Post by Mead »
If you haven't already ordered a new switch, remove it and look at the face of the hazard switch for corrosion of any kind and clean it then try reinstalling. Worked for me when I had the same problem.
Before
After
If not order one. Good luck.
Josh
Barrie, Ontario, Canada
'82 - 712AMB/M
Kaweeka
Post by Kaweeka »
Thanks. We got it apart and cleaned it up but no luck. Will order a new one ASAP and go from there. Appreciate the assistance!
waterdog
Paraguay
Post by waterdog »
i just realize that my hazzard lights works fine for about 10 second then left side starts to die... after a while quit working... is this related to this flasher too ?????
1985 710MS
1985 712MK
Andre
Post by Andre »
open up the lens covers and clean the power and ground contacts.
The four way switch can be "iffy" (mine was) and sometimes one or the other of the rear lights would work, then not work, randomly. I dissasembled the switch, cleaned it, and shimmed it for more contact pressure and it has be working since then... but it will need to be replaced, eventually.
