Rear Emergency Flashers
Posted: Thu Aug 14, 2014 8:54 am
by Kaweeka
"Everything" works (taillights, turn signals, flashers on the front) but there are no flashers on the back. Any clues on how to track this down? Thanks!
Re: Rear Emergency Flashers
Posted: Fri Aug 15, 2014 2:46 am
If the 4 ways only flash the fronts, the 4 way switch assembly will need replacement. The contact board warps or melts preventing signal to rear lamps.
Posted: Fri Aug 15, 2014 10:04 am
by Mead
If you haven't already ordered a new switch, remove it and look at the face of the hazard switch for corrosion of any kind and clean it then try reinstalling. Worked for me when I had the same problem.
Before
- Haz-Sw.jpg (26.68 KiB) Viewed 4579 times
After
- Haz-Sw_4.jpg (25.65 KiB) Viewed 4579 times
If not order one. Good luck.
Posted: Fri Aug 15, 2014 10:14 pm
by Kaweeka
Thanks. We got it apart and cleaned it up but no luck. Will order a new one ASAP and go from there. Appreciate the assistance!
Posted: Sat Aug 16, 2014 4:30 pm
by waterdog
i just realize that my hazzard lights works fine for about 10 second then left side starts to die... after a while quit working... is this related to this flasher too ?????
Posted: Sat Aug 16, 2014 9:36 pm
by Andre
open up the lens covers and clean the power and ground contacts.
Posted: Wed Aug 27, 2014 12:45 am
The four way switch can be "iffy" (mine was) and sometimes one or the other of the rear lights would work, then not work, randomly. I dissasembled the switch, cleaned it, and shimmed it for more contact pressure and it has be working since then... but it will need to be replaced, eventually.
