Tight fit!
Tight fit!
My 710M fits into my garage with less than 1/4" to spare since I added the rear roll bar and canvas. In fact, I had to put 4 cement blocks in the back to lower it enough to get this much clearance!
mm58
Re: Tight fit!
Post by mm58 »
Try letting a few psi out of the tires too.
LibTimothy
Re: Tight fit!
Post by LibTimothy »
I had the same problem.
I fixed it this way.
From inside
All you need is a bigger door.
Timothy
When the only tool in your toolbox is a hammer, every problem starts to look like a nail.
Re: Tight fit!
I went from 33's to 31's and changed the header from a 1x to 1/8 inch plywood.
