Tight fit!
Posted: Sun Aug 24, 2014 7:13 pm
by pinzinator
My 710M fits into my garage with less than 1/4" to spare since I added the rear roll bar and canvas. In fact, I had to put 4 cement blocks in the back to lower it enough to get this much clearance!
Re: Tight fit!
Posted: Sun Aug 24, 2014 7:32 pm
by mm58
Try letting a few psi out of the tires too.
Re: Tight fit!
Posted: Sun Aug 24, 2014 7:54 pm
by LibTimothy
I had the same problem.
I fixed it this way.
From inside
All you need is a bigger door.
Timothy
Re: Tight fit!
Posted: Sun Aug 24, 2014 9:06 pm
by krick3tt
I went from 33's to 31's and changed the header from a 1x to 1/8 inch plywood.
