On the inside I used 3M double sided foam tape, both on the front bezel and along the wire to adhere it to the channel for the run. It is jenky looking, but since I will be fabricating a new door eventually (mines in pretty bad shape) this is temporary and it works, because 3M.
As much as I like the existing brake lights, the thin row of light up high gives a better sense of the dimension of the truck for those coming up behind, and is a very bright, modern addition to it.
