Hello
Has anyone, with a K model, figured out a clever way to store the upper portion of the rear door when driving in warm weather. I am keeping the racks and have a battery box on the passenger side wheel well. Any ideas? And I already know that if I put it there, I won't be able to fit in the seat and close the door.
Eric P
Rear Window Storage
rollingpinz
Rear Window Storage
rollingpinz
- David Dunn
Eric
If you have any space along the waistline, install 2 eye bolts to slide the support tubes into and use a bungee strap to hold the the door top secure against the side wall.
Dave Dunn
Dave Dunn
I mounted it between the rear edge of the table and the leading edge of the rear seats. I originally had an R/V/A/C mounted above,so I filled the hole with the vent. As the vent is very light,no reinforcement of the roof is neccessary,just the courage to cut out a 16" square hole in your roof!
These vents are real cheap for your basic crank-up model with alum cover(less than $20).
Others can be had with power vent capabilities that can both suck or blow
, but I don't know if 24v is an option. I chose cheap aluminum so if it gets "removed"
it would be gentle on my wallet to replace!
I have some pics some where,just gotta find 'em. If you can do any maintenence on a Pinz,this is a super easy project. Side note: My 2nd Pinz has these flip out scooper looking vents mounted a few inches above the outboard edges of the ft bumpers. They work real good also, don't know where to find 'em. I am of the thought that the scoopers and a roof vent may eliminate the need to open windows at all.....TTFN,Mark
Stock means no imagination!
Volvo TGB1317, .95% Morphed!
68 Haffy
68 Haffy
