Replacement fuel pump
Locked
Post by pinzinator »
I found a replacement fuel pump that drops right in and works fine. All you need to do is rotate the upper housing 180 degrees before installation so the fuel lines line up, which takes about 2 minutes. The inlet/outlet tubing is the correct diameter. I run this in my Pinz with no problem, and keep a rebuilt OEM pump as a spare. http://amazon.com/s/ref=sr_pg_2/002-435 ... ley&page=2 Just scroll down to item #48, pump number 151-6753.
milesdzyn
Post by milesdzyn »
Thanks for the info, I have one of those but have not tried it yet. Glad to hear it works. My only concern was that, on mine at least, the rocker cam hangs a little lower than the stock OEM part.
Miles
'73 Pinzgauer 712M
Locked
