UPDATED: Easy/Cheap Dual Note Horn
Locked
todds112
Post by todds112 »
I found a Hella 24v horn on Ebay and bought it. After trying it, it's a really high tone. Not really any louder than original one. I thought about using both for a "dual tone" effect, but don't want to fry a relay or something.
UPDATED BELOW
1973 712M
Post by Jim LaGuardia »
There is no relay, just a simple circuit completed at the button contact.
If both horns together don"t trip the breaker, it should be fine.
Cheers, Jim LaGuardia
"Arch Magus of Machines."
todds112
Post by todds112 »
Have to try it. Thanks Jim.
1973 712M
todds112
Post by todds112 »
Works great, sounds great!
http://cgi.ebay.com/ebaymotors/HELLA-SU ... dZViewItem
I bought this a while ago, never have liked the Pinz horn, thought it was just too weak, and kind of low toned. Sounded like a sick nanny-goat to me. So I got one of these. It sounded just as bad, as it was a very high tone, not fitting a beast like a Pinzgauer.
I decided to try them together. Sounds really good and no breakers are tripping. Has that dual note effect now. Not an air horn but not bad for 20 bucks. Best thing was there is already a threaded bracket just to the right and above the stock horn location, and the bracket that comes on the horn makes it ift perfect in that spot. Some OD green paint and it's good to go!
1973 712M
mjnims
Post by mjnims »
That would be the location for the horn when you have the blackout light.
I think it is funny that the pinz horn is so weak but it sounds like a train horn compared to the one in my Isuzu NPR. Must be a cab forward thing.
Foz
Post by Foz »
http://www.rallylights.com/hella/horns.asp
I used the low tone Hella Superhorn... worked great.
Foz
grayroad
Horn wiring
Post by grayroad »
Did you wire in series or parallel?
MarkPinz
Post by MarkPinz »
Well....I kinda like my stock 710K horn it sounds like the road runner "Beep Beep" from the old Warner Brothers cartoon days :wink: Didn't see Michael's comment on the other thread till now :oops:
Just get in and go....
todds112
Re: Horn wiring
Post by todds112 »
grayroad wrote:Did you wire in series or parallel?
Series. Just added one more slide on connector to the existing one.
1973 712M
grayroad
add on horn wiring
Post by grayroad »
I got the same $20 horn. I piggy- backed the existing wires...I guess that's wired in parallel. It's very loud now! Not anemic anymore! Still kinda high pitched but nice for $20.
Locked
