How much crank case pressure??
Locked
todds112
Post by todds112 »
I never noticed how much pressure there seems to be be in my engine. I was adding a quart of oil while the engine was running. I noticed quite a bit of pressure coming out of the fill tube. It was even splattering oil back at me. I'm assuming this is not good. Does this mean I have significant blow-by?
Is putting new piston rings in something that can be done without removing the engine? How difficult a repair would this be?
1973 712M
todds112
Post by todds112 »
Almost forgot is there a breather to let out excess pressure?
Truck is still running and driving great.
1973 712M
M Wehrman
Post by M Wehrman »
Most engines do not accept oil well when running. Just so it isn't blowing SMOKE out the filler!
Mark
Stock means no imagination!
Volvo TGB1317, .95% Morphed!
68 Haffy
Brickren
Repair
Post by Brickren »
I would like an answer to the rest of his question, if you don't mind. There is a red Pinz that doesn't run on ebay. This is the type of information that would help me decide on what I would fix or send out. Is this some type of repair that can be done somewhat easily in frame or is it easier to pull engine out. It doesn't seem to be that hard, looking at the manual. What kind of time with two guys and a cherry picker to pull engine? How about doing a ring job? Thanks. Brian
1975 710M
2000 Ural Tourist
Post by Jim LaGuardia »
That red Pinz most likely has a bad coil. I noticed it has a civvy kit, and the most common failure is the coil. As far as blow by is concerned, it should be minimal to none. The crankcase vents through the oil filler assembly into the intake air box, so if the carbs are oily, there is blow by, usually from worn rings.
Cheers, Jim LaGuardia
"Arch Magus of Machines."
todds112
Post by todds112 »
That makes sense. Don't really see oil residue in the carbs.
Just for info. How difficult is a ring job? Is this a shade tree job or does it require special skill?
PS: Saw that red Pinz too. Could be a heck of a deal for someone with some time to do some trouble shooting.
1973 712M
Ring job can be done in the truck. It is not too difficult a job if you can read a manual and have common sense(the ability to ask questions before you break something :lol: ), and a few basic tools.
As for the red Pinz, it is either fuel or spark, stone aged technology compared to todays cars :roll:
Locked
