I  am new to the pinz world. I traded for a 1974 710m about a month ago and loving it until yesterday. It acted as if it was flooding on startup and would hit on one cylender. after finally starting it would not idle and ran very ruff backfireing at times. It has mil plugs, I removed and cleaned them they were wet with fuel and old. after installing plugs it will not start at all . help pleaseeeeeeeeeeeeeeeeeeeeeee.
        Thanks in advance
                        Buzzz from Ms.
						I think it died
				pinzdriver
buzzz
Check and see if you lost pwr to the fuel shut off solinods.
tony in az 73 pinz 6X6
pinzdoctor is the name,pinz repair is the game!
WELCOME TO THE PINZ WORLD,
GLAD YOU ARE UP AND RUNNING AGAIN
JUST GOT MINE GOING AFTER NOT TRYING FOR A COUPLE MONTHS BECAUSE OF EITHER NOT BEING HOME OR TOO DARN COLD.  GOT ABOVE FREEZING TODAY SO I THOUGHT I WOULD TRY.
   BECAUSE OF EITHER NOT BEING HOME OR TOO DARN COLD.  GOT ABOVE FREEZING TODAY SO I THOUGHT I WOULD TRY.   TOOK  A WHILE BUT IT FINALLY STARTED.
  TOOK  A WHILE BUT IT FINALLY STARTED.    I WAS SURPRISED I DID NOT HAVE TO CHARGE UP THE BATTERIES.
FYI- EARLY ON IN MY PINZ OWNERSHIP I WAS NOT GETTING A CHARGE TO BATTERY. WAS RED WIRE FROM ALTERNATOR TO CONNECTION PLUG COMMON PROBLEM. THERE ARE OLDER POSTS ABOUT IT.
 I WAS SURPRISED I DID NOT HAVE TO CHARGE UP THE BATTERIES. FYI- EARLY ON IN MY PINZ OWNERSHIP I WAS NOT GETTING A CHARGE TO BATTERY. WAS RED WIRE FROM ALTERNATOR TO CONNECTION PLUG COMMON PROBLEM. THERE ARE OLDER POSTS ABOUT IT.
