Brakes Pulling to One Side
Bryn Pinzgauer
My 710 has developed a tendency to pull to one side during braking. The trouble is, it some times pulls to the left and sometimes pulls to the right and sometimes stops straight. It can do all three on one journey. I have noticed that the pull seems strongest if the brakes haven't been used for a while, and that repeated braking can minimise it or make it go away completely. Does anyone have any thoughts?
Last edited by Bryn Pinzgauer on Sat Apr 12, 2008 1:49 pm, edited 2 times in total.
Pinzgauer 710M
springhill
Pull all tires off and take off the brake drum. There is a sight hole with an adjustment cog. Use a screw driver to adjust the cog. I can't remember off the top of my head which way to turn the cog for tightning the brakes.
Basically check the brake pads for oil. If the drum and pad are oily, clean real good with brake cleaner and fix whatever is leaking.
The brakes should be adjusted correctly every so often. If no one chimes in, I will get my shop manual and go through the process with you.
It is very easy and no big deal.
If you have an oil leak--that can be a big deal, but hopefully your brakes are just out of adjustment.
john
john
"Growing Old is Mandatory
Growing Up is Optional"
springhill
Here is a link that should cover all your questions.
http://www.sdp-pinzgauer.org/html/brake_adjustment.html
Bryn Pinzgauer
Thanks John. I don't think it is a brake adjustment issue though. I have adjusted the brakes many times and am happy doing so. Neither is it an oil leak. I have once had a hub seal go and have replaced it. The hubs are currently clean and fee of oil. For me it is the random behaviour that I find confusing as I don't really know which corner to suspect.
Pinzgauer 710M
How much play is in your steering,i.e. can you rock the steering wheel side to side with no visible wheel movement? If the steering gear is loose it may allow the truck to follow minor issues with the road,making a minor brake issue much worse. Another thing I've found on 2 out of 3 of my trucks is the bar securing the steering box to the body was loose. It's under the floor plate. Needs to be real tight... Hope this helps.
Mark
Mark
Stock means no imagination!
Volvo TGB1317, .95% Morphed!
68 Haffy
68 Haffy
Bryn Pinzgauer
